Problem boring 1850 block to sprint
Just had a chat with my engineering firm and they have hit a snag boring the 1850 block out. Their cutting tool is snagging on a piece of the casting on top of the main cap. I wondered if anyone had encountered this before and if there is a solution?
Options given to mare to put on a stop on the boring tool to reduce the depth, so it doesn't hit this bit of the casting or grinding this bit of casting away. Does anyone have any advice?
Re: Problem boring 1850 block to sprint
Why do the main caps need to be fitted when machining the bores?
I assume the casting he was referring to is at the top half of the main caps, which are part of the block casting. He is saying that is fouling his cutting tool.xvivalve wrote: Why do the main caps need to be fitted when machining the bores?
That is the area that does break. Try to bore only the stroke needed and have as much flesh left around the main bearings.
So what you're saying is I should ask him to restrict to rebore to the length of the piston stroke? Does anyone have exact measurements I could pass on?
Yes. Blocks suitable for competition are the ones that don't have bore marks in that area and unfortunately it's about 1 out of 20 that has. That area is the weak point of the engine and some machineshops bore even deeper at a rebore. I alway's round the edges with a dremel to have not that sharp bore edge.cleverusername wrote: ↑Thu Aug 25, 2022 6:46 pmSo what you're saying is I should ask him to restrict to rebore to the length of the piston stroke? Does anyone have exact measurements I could pass on?
Just the stroke and a bit is enough and will keep the engine stronger.
Here the rounded edges. Also shotpeened this area to have any scratches and edges removed what can become the start of a crack. When the bore marks are already in the threaded holes it's useless for serious power. This is such a rare one that hasn't and will be ok.
And here what happens when bored too deep. When the main bearing area where the bolt goes in has such a crack you can throw away the casting.
Thanks, I will pass that on and see what he says tomorrow. I may well be asking for more advice because I am passing what the engineer told me down the phone. This is outside my area of expertise, so I might not even be describing the problem properly.soe8m wrote: ↑Thu Aug 25, 2022 6:59 pmYes. Blocks suitable for competition are the ones that don't have bore marks in that area and unfortunately it's about 1 out of 20 that has. That area is the weak point of the engine and some machineshops bore even deeper at a rebore. I alway's round the edges with a dremel to have not that sharp bore edge.cleverusername wrote: ↑Thu Aug 25, 2022 6:46 pmSo what you're saying is I should ask him to restrict to rebore to the length of the piston stroke? Does anyone have exact measurements I could pass on?
Ok update, spoke to engineer and he is going to put a stopper on the boring tool. The issue is, he normally run the tool all the way through and waits till it hits the void to stop. In this case the casting was hitting his tool and rapidly blunting it.
So hopefully, by putting a stopper just beyond the length of the stroke, the issue will be resolved.
