Sprint ignition timing.
sprintchris
#1 Post by sprintchris »
Hi,
My Sprint is running a Kent fast road cam and 45 Delortos.
Could somebody please confirm what the ignition timing should be set to and at what idle speed/vacuum connected or disconnected.
Also, exhaust cO content too.
Thanks in advance.
Chris.
dursley92
Re: Sprint ignition timing.
#2 Post by dursley92 »
I run my Sprint engine with the fast road cam and 45DHLA Dellortos as well.
I have set the ignition at 10 degrees BTDC and it runs nicely at that with no pinking.
I do have the vacuum connected as well.
No idea what the CO readings are, it was set up on a rolling road to run sweetly, not necessarily max power.
I typically get about 27/28mpg on classic runs.
Russ Cooper
Dursley
UK
sprintchris
#3 Post by sprintchris »
dursley92 wrote: Wed Sep 21, 2022 8:58 pm I run my Sprint engine with the fast road cam and 45DHLA Dellortos as well.
Thanks for that Russ,
Very helpful 👍🏻
Regards,
Chris.
