Has any one tried Quick release brake couplings ? ebay item 402911670346
Brake hose
Re: Brake hose
Unless your constantly changing a brake callipers or disc.
Why would you.
Possibly made in China.
Why would you.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Re: Brake hose
Where I'm fitting concentric clutch slave, it may be a good idea to fit on the clutch master cylinder, i wouldn't lose brake fluid from the master cylinder when i remove the gearbox
Re: Brake hose
Totally understand now.
Although I will be fitted a concentric clutch slave also the the RX8 gearbox.
No quick release .
No quick release .
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Re: Brake hose
My Vauxhall gearbox also uses a concentric slave cylinder, mated to the Toledo master. I've disconnected it twice since original fitment, both times it took only a few seconds to gravity bleed it on completion.
I know you love your gadgets Dave, but honestly, don't lose sight of the K.I.S.S. Principal!
Re: Brake hose
That is sent from China. Why on earth would you want to use something that is not branded/tested to a high std fitted to your brakes??
If you are looking for "clever" solutions, try "Think Automotive" where similar stauff may be available, but at several times the cost as it is made to a proper specification from proper materials.
But like others have said, it takes a very short time to bleed a CSC. Some do not even have a bleed connection, I am quessing they are autobleed?
Re: Brake hose
Dave actually wants it for his clutch not brakes.cliftyhanger wrote: ↑Sat Nov 19, 2022 7:52 am That is sent from China. Why on earth would you want to use something that is not branded/tested to a high std fitted to your brakes??
But yes seller is registered in China.
Personally I wouldn’t use one as I don’t think it needs it.
Chinese or not.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
