Pistons
pigeon56
Pistons
#1 Post by pigeon56 »
Hi
My 1850 engine is being rebored but i need to find at set of pistons which are standard +20 thou.
Unfortunately the machine shop have told me that they are unable to rebore further to take a bigger size pistons due to the size of the liners.
Re: Pistons
#2 Post by Mad Mart »
Do you want new or used?
pigeon56
Re: Pistons
#3 Post by pigeon56 »
Hi
Prefer new but if i cannot get new would consider used.
cleverusername
Re: Pistons
#4 Post by cleverusername »
Are you sure they can't bore it any larger? I have had an 1850 block bored up to Sprint size. That is 87mm to 90.3mm, which is 3.3mm.
Now to be honest I don't really understand imperial measurements but I am pretty sure that is way over 20 thou.
Re: Pistons
#5 Post by Mad Mart »
I had the same thought. 0.020" is only just over 0.5mm.. They should easily be able to bore it to +0.040".
Re: Pistons
#6 Post by xvivalve »
The OP says it is a linered block, so it would be the residual wall thickness of the liners which dictates what they can and cannot do.
Re: Pistons
#7 Post by Mad Mart »
Liners are fitted from the factory. They have a certain OD and ID. The ID is bored & honed to standard size and are able to be bored out to at least +.040" if not +0.060". Even if replacement liners have been fitted, the OD would still be the same as the originals.
Re: Pistons
#8 Post by xvivalve »
I too thought that until recently Mart, particularly as liners are shown in the factory parts book, but those who know better contested this not too long ago…
https://forum.triumphdolomite.co.uk/vie ... rs#p327975
Re: Pistons
#9 Post by Mad Mart »
So is that just the 1850s? as I've never come across a Sprint block without liners. I had assumed the 1850s were the same.
2Toledos
Re: Pistons
#10 Post by 2Toledos »
pigeon56 wrote: Sat Jul 15, 2023 12:12 pm Hi
Alas, I only have new Hepolite sets either side of that: Standard and +0.040". :roll:
'74 4 door Toledo with 1850HL 'transplant' (Tara)
'71 2 door Toledo Sprint (as yet unnamed :?: )
'06 VW B6 Passat Estate 2.0 FSI (The Workhorse)
TBC - New baby on the way :wink: ....
