Sprint Prop Shaft CV Joint Rubber Boot
Philip Larmour
#1 Post by Philip Larmour »
Has anyone been able to find a supplier for the Sprint Prop Shaft CV boot?
We can readily find companies in Australia to recondition the CV joint itself, but they all fit drive shaft rubber boots as part of the overhaul process. The result is because the prop shaft rotates considerable faster than drive shafts, the rubber boot disintergrates as a result of the higher rotational speed.
Re: Sprint Prop Shaft CV Joint Rubber Boot
#2 Post by xvivalve »
I approached the folk who remanufactured the quarter light seals for us about costs for the Sprint gear lever gaiter, which they could do, but the cost of tooling seemed prohibitive at the time due to limited demand.
It’s likely they could produce the prop cv boot and it’s possibly more viable because many props of the time used similar, if not identical joints, and an economy of scale would come into play. However, we’d need a good pattern for them to measure…
PollyB
#3 Post by PollyB »
Put two more on your list for the Gear lever gaiter Alan
It isn't Orange!!!!!!
Aye…
#4 Post by sprint95m »
xvivalve wrote: Thu Jul 20, 2023 9:09 am I approached the folk who remanufactured the quarter light seals for us about costs for the Sprint gear lever gaiter, which they could do, but the cost of tooling seemed prohibitive at the time due to limited demand.
This is doing my head in, trying to think of another car with the same prop shaft CV joint!
The best I can come up with is a Ford Capri, but I don’t imagine they will be a source of boots
given that their one is held in place by cap head screws rather than a steel band.
I actually have a Capri prop here so will investigate in the daylight
Ian
cliftyhanger
Prop CV boots
#5 Post by cliftyhanger »
sprint95m wrote: Thu Nov 09, 2023 12:00 am
Ian
Spitfire 1500 is a possibility. Same era/manufacturer
When I visited Feltham Propshafts to balance a prop, I had a chat with the bloke and he reckoned changing them was something they could do. As I had just replaced my centre bearing on my dolly prop (with a genuine Transit version)
#6 Post by xvivalve »
Yep, I have Spitfire props here with the same cv joint...
Philip Larmour
#7 Post by Philip Larmour »
xvivalve wrote: Thu Nov 09, 2023 11:56 am Yep, I have Spitfire props here with the same cv joint...
If they are the same part as the Sprint boot then it is most likely NLA as well.
As per my original post the replacement needs to be a tailshaft CV boot not a FWD drive shaft boot. It is the rotational speed of the tailshaft that destroys the FWD boots.
If a replacement one can be found i will take three boots.
Philip
#8 Post by xvivalve »
Yes, I agree, but at least it creates a greater market for a remanufactured product thereby making economy of scale more viable.
To progress remanufacture we ideally need a NOS item...or at very least a very good condition used item...from which a pattern can be reverse engineered.
Sprintparts
#9 Post by Sprintparts »
I am going to bump this back to the top of topics again.
We still require the Sprint tailshaft CV boost if anyone can help, I have 4 tailshafts sitting here needing boots.
thanks
Car #42. Broadspeed Built 1974 BTCC Sprint and Austrailan Group C Touring Car.
Car #43. RHLDT Built Australian Group C Touring Car.
#10 Post by xvivalve »
I have a Spitfire propshaft here which appears to have the same CV joint (subject to precise measurements) on it which I hope will provide a decent enough used boot as a pattern for reverse engineering...I just need to find time to take it apart!
A recent parallel post has timely reminded me...
Sprintparts
#11 Post by Sprintparts »
xvivalve wrote: Wed May 08, 2024 8:16 am I have a Spitfire propshaft here which appears to have the same CV joint (subject to precise measurements) on it which I hope will provide a decent enough used boot as a pattern for reverse engineering...I just need to find time to take it apart!
Sounds hopeful, we wait in anticipation. :D
