Does anyone recognise these bearing part numbers?
S2256SA and s2254SA
Hoping that they are original 1850 or Sprint main and big end bearings.
Original bearing part numbers
Re: Original bearing part numbers
I have some standard sized Glacier AE rod bearings, and whilst the box part number is B4490SA each bearing is stamped S2256SA.
...and the other number is stamped on some oversized AE main bearings I have, so so long as they also have STD stamped on them rather than 010 etc then your hopes are fulfilled!
Thanks Alun
