Any one know much about Corsa D electric steering column how big is the motor ? are they smaller than the Corsa C set up
Thanks Dave
Corsa C Steering Cloumn
- Jod Clark
- Saving up to join the Club!
Re: Corsa D steering Column
Yes its bigger than Corsa C, broadly the same as the 2006> Fiat Punto unit, the Corsa D being a Punto in a different jacket.
- Jod Clark
Possibly Fiat Seicento, if you can find one...
On the Corsa C steering column, there's a ECU that's mounted round the column, does that get hot,? on the back of the ECU there's fins are they a heat sink or just the grip to mount round the column ?
Thanks Dave
Thanks Dave
Re: Corsa C Steering Cloumn
It turns out its just the mount to go round the steering column, but still cant work out how to remove it from the ECUnew to this wrote: ↑Sun Jun 09, 2024 12:39 pm On the Corsa C steering column, there's a ECU that's mounted round the column, does that get hot,? on the back of the ECU there's fins are they a heat sink or just the grip to mount round the column ?
Thanks Dave
