Splitting the Sprint propshaft
cleverusername
#1 Post by cleverusername »
I am splitting a Sprint propshaft to get at the centre bearing. So far I have got everything apart without breaking anything but I am stuck at the final stage. Getting the bit which contains the ball bearings of the CV joint off the splines (I have removed the cage).
The instructions I have seen say just give it a whack with a hammer but I am a bit warry of doing that, just in case I have missed something I need to remove.
Is it really just a case of put it in a vice and hit it till it comes off?
gdc2john
Re: Splitting the Sprint propshaft
#2 Post by gdc2john »
Yep, it takes a really good wack, its held on by a internal ring clip. Ive also had success putting the shaft in the vice and driving it off with a drift.
