Triumph Dolomite Boot Seal
David Embery
#1 Post by David Embery »
Hi,
Pictures below show the replacement boot seal I have received for my 1972 Triumph Dolomite 1850.
Does anyone have any views on whether this looks like the correct seal? Just looking at it next to the car, it looks rather too fat and therefore unlikely to fit. Is there another version of the seal I should be getting instead?
Would very much appreciate hearing member’s views and if there are any particular points/tips I should keep in mind in order to successfully fit?
David
Re: Triumph Dolomite Boot Seal
#2 Post by xvivalve »
The boot seals you can buy today are indeed too fat and may prevent the boot lid from shutting or if it does not sitting flush. NOS if you are lucky, or find a good used one....
tangocharlie1
#3 Post by tangocharlie1 »
Where did you get it from ?
As already stated good nos is your best bet, but i have known people use COH Baines with positive results it may prove a decent alternative.
https://coh-baines.co.uk/search?q=boot+ ... h+dolomite
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
David Embery
#4 Post by David Embery »
Thanks Alun & Charlie.
:D
I’ll give the alternative a go as suggested by Charlie.
#5 Post by xvivalve »
Before you buy one from Baines, ask if they supply the place you bought the first one from...they probably do!
David Embery
#6 Post by David Embery »
Cheers Alun. I’ve sent an email to lhdclassicparts on eBay. I’ll keep you posted on progress. :D
10yearsafter
#7 Post by 10yearsafter »
I have just had one from Chris Wittor fits perfectly. Rimmers were not good.
Bob
David Embery
#8 Post by David Embery »
Cheers Bob. I’ll take a look at Chris Whitor’s web-site. :D
