Fuel Injecting the Sprint
Aye,....
#61 Post by sprint95m »
There was a blog on the Club Triumph website from Mike Weaver (I believe)
that detailed his EFI conversion.
Unfortunately this seems to have disappeared, which is a pity because it was informative.
I did do some research on EFI conversions (in general)
and concluded that a single throttle body/plenum arrangement is not necessarily easier
because it is important to get both the shape and volume correct for the best result.
(Back in the days of the DSR I remember someone used an Escort XR3i setup adapted to
his Sprint and I don't know if he ever got the plenum right. Obviously things have moved on since
the days of an XR3.)
For low down torque it is important to have as long an intake as possible, preferably straight as well.
The ITB set up on Keith's car should be okay in this respect due to the long trumpets he has employed.
As you said it is a cracking car with a lot of interesting features.
JPSPRINT
Re: Fuel Injecting the Sprint
#62 Post by JPSPRINT »
Superb links Ian (and great car if you're reading this, Keith!)
Steve I understand the honesty of modern EFI but you'd have to admit those Jenvey's look so right in there. I'm biased though as the look and sound of Webers were the dream growing up, even on other marques!
The parts list on that Emerald site looks excellent too! Very impressive and complete!
pigboy306
#63 Post by pigboy306 »
Late to the party. I injected a tr7 with speeduino based system . I used the tr7 manifold and made a plenum with single body throttle body. Keep it simple.
The car was night and day difference against carbs. Very noticeable on club runs. It ran 137 bhp on a dyno nothing else much done.
I am now going for a sprint head in and injectors.
The manifold I had machined . Although with hose tails I am having a fuel rail made as well.
Speeduino is a great system allowing you to tune or self tune on the fly.
new to this
#64 Post by new to this »
You can buy fuel rails from Trigger wheel .com, i made my own setup still got to buy the ECU then try and get it started
yorkshire_spam
#65 Post by yorkshire_spam »
pigboy306 wrote: Sat Mar 29, 2025 1:49 pm Late to the party. I injected a tr7 with speeduino based system . I used the tr7 manifold and made a plenum with single body throttle body. Keep it simple.
Nice work!
Sprintparts
#66 Post by Sprintparts »
This my set up. A Weber manifold with a set of Aliexpress DCOE ITB's.
Car #42. Broadspeed Built 1974 BTCC Sprint and Austrailan Group C Touring Car.
Car #43. RHLDT Built Australian Group C Touring Car.
yorkshire_spam
#67 Post by yorkshire_spam »
Sprintparts wrote: Wed Apr 09, 2025 11:08 pm Image
That's really nice and neat!
Sprintparts
#68 Post by Sprintparts »
I don't know who you are doing your "timing" but this is what I am going to use.
BMW M20 EFI crankshaft damper. I already had a crank to damper adaptor in my spare parts bin from one of my old race motor set ups. (use a different damper these days). I believe that these adaptors are now made in the UK (Sprintspeed). Sensor is from a Renault Clio 2, only because I have numerous spares for my Clio race car.
Due to the scarcity of Sprint distributors, I have used a TR7 (late model electronic) body with a sensor for the home signal trigger.
pigboy306
#69 Post by pigboy306 »
Timing is using a trigger wheel to the Sprint crank pulley. I did similar with the tr7.
I have now got a fuel rail
The car starts and runs now. The idle though is very lumpy, i have read this can be an issue with sprint engines, although i am still hunting for any air leaks.
Moving forward I think coil on plugs will be a nice addition. Anyone fitted Coil on plugs?
Sprintparts
#70 Post by Sprintparts »
pigboy306 wrote: Mon May 19, 2025 9:08 am Moving forward I think coil on plugs will be a nice addition. Anyone fitted Coil on plugs?
Yes.
Here is a photo of the mock up. Coil packs are from a Mazda/Ford V6 3 litre engine. Aluminium spacers are bolted to the cam cover so the coil pack and be secured. Must say that the engine is still to be fitted to the car, so only a "theory" and not a proven concept.
cliftyhanger
#71 Post by cliftyhanger »
Sprintparts wrote: Fri Apr 11, 2025 8:28 am Image
May I ask why you need this as well as a timing wheel?
Sprintparts
#72 Post by Sprintparts »
cliftyhanger wrote: Fri May 23, 2025 12:40 pm
For sequential ignition and fuel, rather than batch fire (wasted spark).
cliftyhanger
#73 Post by cliftyhanger »
Sprintparts wrote: Fri May 23, 2025 1:03 pm For sequential ignition and fuel, rather than batch fire (wasted spark).
Gotcha!
pigboy306
#74 Post by pigboy306 »
Ooh i like that very smart and tidy mine isnt so smart but works none the less.
pigboy306
#75 Post by pigboy306 »
Sprintparts wrote: Thu May 22, 2025 11:24 pm
Yes.
Seeing you are in Australia I may not have found the correct plug but were these the ones you were using? https://ebay.us/m/PJk5DT
