It's just a flesh wound
zombeh
#1 Post by zombeh »
Managed to do this on the way to work this morning :(
So I'm after a wing, eyebrow, headlight panel and ideally front inner and outer valance, preferably not anything made by rimmers.
Anyone know where to find these?
DavePoth
#2 Post by DavePoth »
Without looking at it properly, the club headlamp mounting panel may suffice to repair the valance, which just leaves the wing and eyebrow. is the inner wing damaged at all?
triple tango
#3 Post by triple tango »
I've got a bumper & lights
DavePoth
#4 Post by DavePoth »
Just out of interest, what did you hit/get hit by?
zombeh
#5 Post by zombeh »
I misjudged the level of grip on the road while pulling out of my drive this morning, the back end tried to get away from me, corrected too much and too late, zigzagged down the road for a few yards slowly getting it under control and ended up in the side of a xsara picasso.
Just looked at the list of club repair panels and it does look like the inner and outer valance repair sections might cover all the damage there.
Hard to say how bad the inner wing is without removing the outer, I think it's persuadable back to where it should be.
Tripple custard:
I've got plenty of electrical and mechanical spares, just bodywork I'm missing (broke an 1850 that was beyond sensible repair a few years ago)
2F45T4U
#6 Post by 2F45T4U »
Looks familiar :cry:
Mine had slight crease in the inner wing, a hammer would of sorted it out but as I found rust whilst removing old metal I ended up replacing a section of the chassis memeber below the wing. And as the other wing had a big tear in it (old woman pulled out on me *bang* bounced off her in to parked tipper truck hence tear) I replaced the whole front end in one :D £50
Easy :D
David6214
#7 Post by David6214 »
Its all good. I'd go for more slightly more expensive parts than Adam if I were you......
Where are you mr Zombeh? (PM me if you prefer)
zombeh
#8 Post by zombeh »
Just over the water from you :) newportish
2F45T4U
#9 Post by 2F45T4U »
Im in Port Talbot ish :D
zombeh
#10 Post by zombeh »
Not the Newport near you Adam, the one on the Isle of Wight
2F45T4U
#11 Post by 2F45T4U »
:lol: Ahh right
#12 Post by DoloWIGHTY »
Have you contacted Anglea or Graham see if they have any local contacts?
zombeh
#13 Post by zombeh »
Graham had a look at the car when I was taking it out to austin morris in afton for a quote, there was some concern that there might be structural damage but it looks to just be cosmetic.
Frank said "insurance wise it's not economically repairable, but if you can get the parts I can fix that"
#14 Post by DoloWIGHTY »
Frank is a great bloke. If anyone can fix it Frank can! :thumbsup:
#15 Post by xvivalve »
I have a couple of s/h driver's wings, not perfect, but most useable.
