Sump removal
Sump removal
Can anyone tell me if you can remove the sump on a Dolly Sprint? With the engine in situ... It looks a bit tight... I change the oil & filter every year, just thought I would clean out any sludge that may have built up... Is this possible or is only done with engine out, cheers Dave...
1977 Sandglow Sprint...
It can be done with engine in situ. I'll try & find the thread where we talked about it a few weeks ago.
Edit: Here you go:-
viewtopic.php?t=4186&highlight=sump
Edit: Here you go:-
