Where can i get some of these
ALGIK
#1 Post by ALGIK »
216903 bushes
Rimmers want £25.00each eeek
tinweevil
#2 Post by tinweevil »
Chris Witor £9.34 each inc vat.
Tinweevil
ALGIK
#3 Post by ALGIK »
tinweevil wrote:Chris Witor £9.34 each inc vat.
Tinweevil
:thumbsup:
#4 Post by Mad Mart »
I got a set from CW (along with various other bushes), they are a polybush with a s/s insert, not like the originals. I never fitted mine as I wasn't sure they were correct.
ALGIK
#5 Post by ALGIK »
Mad Mart wrote:I got a set from CW (along with various other bushes), they are a polybush with a s/s insert, not like the originals. I never fitted mine as I wasn't sure they were correct.
Yes the originals give some for and aft movement
Will be fitting originals ...
smifter
#6 Post by smifter »
The standard unit is more of a rose joint so there's not a big advantage of going poly here. Plus the standard bushes need to be pressed out on a hydraulic press - a bench vice and a couple of sockets usually wont be up to it.
Saying that, I've used the polybushes and have to say the improvement in front end stability is tremendous, this was probably due more to replacing them all at once though rather than this particular bush - I replaced it anyway as the poly bushes are that much cheaper and easier to replace in the future.
G
ALGIK
#7 Post by ALGIK »
smifter wrote:The standard unit is more of a rose joint so there's not a big advantage of going poly here. Plus the standard bushes need to be pressed out on a hydraulic press - a bench vice and a couple of sockets usually wont be up to it.
G
I have replaced the upper wish bones with nylon a few years ago i have a adjustable tcas with rose joints and am putting originals back in the bottom arm
I have a press and it took 3 tons pressure to remove the old bushes
hope this sorts the front end out :?
slant4
whats the problem
#8 Post by slant4 »
As a matter of interest, camber problems?
Dollyboy
#9 Post by Dollyboy »
...oooooh, dont go there!
:funny:
ALGIK
Re: whats the problem
#10 Post by ALGIK »
slant4 wrote:As a matter of interest, camber problems?
No just comming down the back straight at donnington hitting the brakes for the right hander the wheels feel like there dancing about,
I had the camber set to 2 deg.
