Sprint Choke cable
jeffclane
Sprint Choke cable
#1 Post by jeffclane »
not on the club parts list, are Rimmers the cheapest option?
cheers
Jeff
MalcGE
#2 Post by MalcGE »
Your 'decent' local high street car spares outlet might be worth a try. Mind you, these days it's all ICE, 'Loys and Large Zorsts' for most- how times change.
Alexander Engineering used to make a unviversal cable, they use them on most BL /MG products. Not quite as per the original Triumph which was a pull and push, the BL one are a pull and twist to Lock, does the job though
jeffclane
#3 Post by jeffclane »
thanks Malc, how's the dizzy cap/leads sourcing going?
MalcGE
#4 Post by MalcGE »
Took delivery just before X-mas. Std Spec Sprint Lead sets with remanufactured std plug boots. Leads will fit a std spec remanufactured cap, but the cap will need to be drilled out very carefully (wasy to do on the remanufactured caps cos they are a slightly softer plastic than the std ones)
Caps and Leads now in stock :D
