Even more methods of sorting the W/P clearance.
Clocking in TDC using a dial test indicator.
Flywheel was balanced on crank and is also on TDC.
Grease the water pump before fitting, failure to do this will result in the famous stuck water pump in block thread.
Using all gaskets in the set a little piece of plasticene is wrapped in selotape and placed on the waterpump bolt (this is my method)
like this and then put on the cover
tightened down securely.
measure the squished gauge and take away the thickness of gaskets to achieve .010"-.025" running clearance, too tight will strain the jackshaft too loose will cause mesh problems with skew gears, both wreck jackshaft and hence engine.I think mechanics have not given enough care to this important piece from day 1.
After setting pump try turning the jackshaft by hand and it should be free and smooth. The shaft in this block is a very nice fit and not sloppy as some are in high mileage engines.
I run an electric fuel pump so this is a blanking plate that I make to cover the redundant hole.
