andrew. Thanks for the concern
Makes me know that people are looking at the pics
The rust at the bottom of the wing was both cut out and treated with rustkiller. I know that fibreglass isnt the best but its what im good at and itl hold
In reguards to the bottom of the windscreen there wasnt really any rust there to be honest just a couple of bubbles that had burst revealing a bit of surface rust underneath. The metal then recieved a very thin layer of filler to fill in any small bumps. You are correct about the wing picture though. I did just wire wheel most of the paint off then leave an edge where the paint and metal meet. and I also admit that i attemted to use filler to cover it up. but after about 2 hours of sanding I realised that it was a terrible idea and put some rough paper on the sander and took it all back off again then feathered it as you say. Ill try and find a pic. Not sure if i took one.
In reguards to my spraying I will be using cellulose with a large compressor and and expensive gun. I didnt know it was illegal to spray outside!?! Ill be putting sides on my "booth" and wearing a very filtered mask and doing it anyways!
Thanks for the advice!
Please pick holes in what i have said because fu*k*ng up is one of the best ways of learning!!!!
Ken. I needed the car up quick and there was a crane nearby! job done!! I know its not ideal but it wont be there long and i dont want to use my cills or anything as jacking points.
Cheers for the comments guys. Probably wont be anymore done for a couple of days now as im road tripping with adam on saturday and the again with mathew on sunday
richard
