Well no that's certainly trueJon Tilson wrote:Not a lot of point in poly bushing the arb if you then leave it out is there?
ho ho...
I hadn't finished painting it at the time
'Tis done now and me other parts have turned up too.
A few strategic bolts are left loose on the new frame so hopefully I'll be able to get the ARB back in before the swap out, if not then like you say, I'll do it on the car.
Next Saturday is booked for the removal.
Easter? for the reassembly
Gonna split the engine and 'box to replace the cross shaft bushes etc. as I'm still not 100% happy with the clutch.
This is despite using a resealed master, NEW slave, braided hose, DOT5 fluid (not that DOT5 will make any difference, it's just to match the brakes), pedal box cotter pins replaced and re-shimmed for a snug fit.
Other jobs when it is all out is fit the starter from the red sprint as I know it cranks for England and the current one is sometimes a bit reluctant.
Try to fix as many oil leaks as I can. Gearbox nose or rear main possibly? Not sure...
Paint the block
Scrub the engine bay
Remove a few bits of rust in and around the bay, seal with POR-15 and spray back to body colour.
Fit a poly lower steering bush
That's about it I think for this little task
