Silverstone Track Day
rich
#16 Post by rich »
never done a trackday but been down to a couple to check them out and heard it said that thje fuel lays in the tanks too long.
#17 Post by Mad Mart »
Well if anyone is around tomorrow, bring a helmet & I'm sure I can take you out a couple of times...cheap day out!
Hans ten Broeke
#18 Post by Hans ten Broeke »
Mart,
What tires and size including rim size, rad or diagonal do you run, just qurious.
Hans
#19 Post by Mad Mart »
Hans - I run Yokohama A038 185/60/13 on Compomotive 5 spoke 6x13 wheels.
DavePoth
#20 Post by DavePoth »
How did it go?
#21 Post by Mad Mart »
Bloody excellent Dave! :jump4joy:
I'll have to give a bit more detail tomorrow as I'm absolutely knackered. Got up at 4:45am, left home at 5:30am. Got back at 19:10pm. Then I had to go Bowling. :-({|=
#22 Post by Mad Mart »
As I said it was a great day, well organised & the weather stayed fine and my Sprint got me there & back in one piece (always a bonus).
After signing in and getting our numbers & wrist bands we had the usual pre-track briefing. The day was divided into three separate sessions; Lotus on Track had the first session with MGs on track taking the other two, ClubTriumph members mingled with the MGs. All sessions lasted 20 minutes and believe me, driving a circuit for 20 mins at a time is pretty knackering. I think it's more mentally tiring than physical.
The first session for everyone was to follow a pace car around the circuit for three laps at no more than 50 mph. The pace car would follow the racing line & the theory was that everyone would follow that line, but by the time it got towards the rear of the convoy...well lets say it's a bit like Chinese whispers. Anyway, that took up most of the first session but we did manage a couple of flying laps once the pace car pulled into the pits.
I found the circuit to be quite intimidating to start with as it’s quite wide & I felt a bit lost at times on that vast circuit of over 3 miles long. After the first proper session I was a bit disappointed as I felt, and probably was, all over the place, either braking too soon or too late & getting the race line completely wrong. But that was short lived. The next session I had learned by my mistakes & determined to get it right I was gradually carrying more speed through the twisties. What a contrast that session was to the previous & I got back to the garage with a big grin on my face. From then on it was pedal to the metal all the way, well quite a lot anyway. I did have a couple of moments; both at Vale. The first one I just out braked myself & had to run onto the grass, a bit bumpy but still, the second, after trying to keep up with the Herald estate that I’d let pass me a lap ago, I took the corner too fast & spun.
The best session was the last one. I lined up behind Jon Jackson (Sierra brake man) in his Sprint. It was brilliant, Jon was off like a bat out of hell & caught me napping but I soon caught up once he hit traffic. Then it was a case of scything through the slower cars (well actually, waiting ‘til they let us pass) MGFs, Midgets, even a Rover 75 V8 supercharged estate thingy (must admit, that V8 sounded awesome).
Ah! Well, back down to earth now, which reminds me, Life on Mars is just about to start.
KWM338R
#23 Post by KWM338R »
I don't believe a word of it :wink: , got any video footage?
Edit: Just went to General forum and found the answer :oops:
Phil
#24 Post by Phil »
Mad Mart wrote:.. I have a 4.1:1 diff...
Sorry, was reading through this topic and though I might as well learn something..
What does that actually mean ? :roll:
Phil
SprintV8
#25 Post by SprintV8 »
Standard Sprint diff is 3.54:1 Ratio
4.1:1 is a different ratio diff that will help the Sprint pull out of corner's quicker.
The downside is a slower top speed.
Not that you need much top speed on the track.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
tinweevil
#26 Post by tinweevil »
The ratio is the number of input turns to output turns of the differential. For example with a 4.11:1 when your prop shaft is turning at 4110 rpm your wheels will be turning at 1000 rpm. With a standard sprint diff when the wheels are at 1000rpm the prop shaft is only doing 3540 rpm. I won't go into the details of the engine to prop ratio except that in 4th gear it is 1:1; engine rpm = prop rpm.
So a lower ratio diff gives a more leisurely cruise as engine speed is lower for a given wheel rpm. A higher ratio makes the car accelerate better because you have lower gears. The difference between 4.11 and 3.54 is 14% We all know you change down a gear to get better acceleration to overtake someone. Marts car permanently in 14% lower gear than standard.
Hope that makes sense!
Tinweevil
Sprint36
#27 Post by Sprint36 »
Standard is 3.45:1
David
#28 Post by Mad Mart »
...and my ratio is 4.1:1 not 4.11:1 :lol:
tinweevil
#29 Post by tinweevil »
I sit corrected :lol:
Tin
#30 Post by Mad Mart »
I'm glad most people understand the smileys. :D
