The really early 1700 and 1850 saab engines should almost just bolt in. I reckon a B engine will fit without much hardship except getting the exhaust in, if you're turbocharging it this will be a pain in the arse.JPB wrote:That hasn't prevented people fitting such units as the Lotus slant four into Dolomites. Where there's a will, etc.triumphtoledo wrote:Not as far as I know. The SAAB 2.3-litre unit may have Triumph roots but it doesn't even share any components. Even the 99 Turbo engine (B / H series) would not be easy.![]()
Since saab put them in backwards the injection system will all be pointing the wrong way.
The early slant H engines are similar in terms of difficulty to fitting something like the lotus, there's a reason the sprint has such a weird head.
A 2.3 should be no harder to fit than any other inline 4, if you really want to put it in there it will fit, extensive cutting and welding will probably be required.
