Dolomite rear view mirror repairs
Re: Dolomite rear view mirror repairs
#16 Post by soe8m »
The Italian Dolomite sprint club does remake these for years now with succes.
cleverusername
#17 Post by cleverusername »
I suspect the problem with all these repairs, is you are not killing the crack. The end of the crack is a stress riser, in a brittle material that means that once a crack starts, it rapidly propagates through the material.
You need to drill a hole at the end of the crack to stop it, then repair it.
GrahamFountain
#18 Post by GrahamFountain »
The first I knew of the problem was when it fell in two pieces.
Jeroen, I can't find anything on Google on these parts from the Italians. Do you have a link or anything?
Richard the old one
#19 Post by Richard the old one »
Just to update everyone. The one I repaired is still in one piece and the car is in almost daily use.
geeksteve
#20 Post by geeksteve »
cleverusername wrote: Sun Mar 22, 2020 9:56 pm I suspect the problem with all these repairs, is you are not killing the crack. The end of the crack is a stress riser, in a brittle material that means that once a crack starts, it rapidly propagates through the material.
There isn't a crack any more though, it's in two halves.
GrahamFountain
#21 Post by GrahamFountain »
geeksteve wrote: Mon Mar 23, 2020 11:03 am There isn't a crack any more though, it's in two halves.
Yup, that were my situation.
I think the araldite might have worked longer term if I'd clamped it together without the stalk in the broken mount. But I was afraid it would brake again when I put the stalk back in.
geeksteve
#22 Post by geeksteve »
GrahamFountain wrote: Thu Mar 26, 2020 8:51 am But I was afraid it would brake again when I put the stalk back in.
Mine did exactly that..
Mine's the one wrapped in electrical tape :lol:
GrahamFountain
#23 Post by GrahamFountain »
Jeroen, Is there nothing more on the Italian source - for when the Corola is over?
Hmm......
#24 Post by sprint95m »
I have a broken mounting here and think I will try using Devcon to repair it.
Any reason not to try this adhesive?
thanks,
Ian
#25 Post by soe8m »
GrahamFountain wrote: Sat Mar 28, 2020 12:05 pm Jeroen, Is there nothing more on the Italian source - for when the Corola is over?
Yes. The communication is a bit slow but I got a confirmation there are a few available.
GrahamFountain
#26 Post by GrahamFountain »
soe8m wrote: Mon Mar 30, 2020 4:19 pm
Jeroen,
You got a link to order them from?
matienzo
#27 Post by matienzo »
Funny the way these posts re-materialise every once in a while! So our repair continues to function. This is a cheap home fix option that worked for us.
By now 3-D printing the base plate is probably not beyond the realms of possibility and budget and this is indeed what the Italian Club may have undertaken successfully. It will be interesting to hear back from them. In the meantime does anyone here have access to a 3-D printer that would be willing to prototype this item?
Steve and Nic
Larger garage needed
gmsclassics
#28 Post by gmsclassics »
About 7 or 8 years ago after failing to repair my mirror mount with Araldite, I modelled a 'new' one around the ball on the mirror stalk from a product called Selleys Knead It Steel. http://www.selleys.co.nz/trade/speciali ... d-it-steel
While not perfect, it is black and in its shaded location looks no different to the original. No vibration or any other issues for example with adjusting the mirror itself.
Would it snap off in the case of an accident? I expect so but haven't tested that. But then it is a car with an ANCAP rating of one or below so I have to drive to avoid others accidents!
Geoff
IMG_1539 (002).JPG (121.06 KiB) Viewed 1707 times
#29 Post by soe8m »
The Italian made is machined from a sort of plastic/nylon. Rigid enough to keep the mirror in place and flexible enough not to break.
There's no link or whatever and before something is possible again in Italy will take while.
Jeroen.
new to this
#30 Post by new to this »
Cant get to my car at the moment,but where do they brake is it the mirror end or where the mirror attaches to the body work
mines broke from the body work end,i see Paddocks sell a bracket for the Stag mirror are they the same for Dolomite
