Oil transfer plate, question
dursley92
Re: Oil transfer plate, question
#16 Post by dursley92 »
So far as I can recall, my adapter is just like Tony's and I don't think there will be any obstructions to good flow caused by that centre bolt. In depth investigation will have to wait until the next time I take the filter off. I will be sure to report back if I find anything interesting.
For what its worth, last time I changed the filter I also removed the oil cooler a previous owner had fitted as I think the oil was running too cold in my TR7 and causing sludge in the sump. The stuff in the bottom of the sump was the texture of thick honey and about 1cm deep. See picture.
I had always used good oil and changed it frequently so that was a surprise. I thought about using the oil thermostat I have in stock but decided it wasn't necessary on a road car and took the whole lot off. The cooler pipes came off a modified transfer cover with a couple of threaded outlets. Its all sitting on the shelf if anybody needs one.
Russ Cooper
Dursley
UK
shaunroche
#17 Post by shaunroche »
soe8m wrote: Sun Jan 05, 2014 9:27 pm That is the main gallery so oil into that.
Oil into that...in which direction? Is that the return from the oil cooler, or the feed?
I suspect that oil comes out of that port and into the oil thermostat and returns on the right when coming back from the OC....yes?
#18 Post by soe8m »
The red dot is the into the engine side.
#19 Post by soe8m »
Here you are.
shaunroche
#20 Post by shaunroche »
Excellent thank you, got there in the end.
This thread wont be getting a Chrystal Clear award anytime soon! 😉
