Engine cooked...?!
grifterkid
Re: Engine cooked...?!
#16 Post by grifterkid »
I will be in touch very soon Mr.T, thanks again...
Howard81
#17 Post by Howard81 »
If it is the water pump they're easy to replace - about £35 and three nuts holding it on!
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
cleverusername
#18 Post by cleverusername »
I have a 1500, that can get hot in traffic on a warm day. The problem is the fan on the front, it is turned by the engine, so when you need maximum airflow, when stationary, the fan is turning at minimum speed. Combine that with any weakness in the cooling system, crud in the radiator for example and your little triumph tries to turn into a kettle.
#19 Post by Jon Tilson »
No word from you Ash?
What's happening? Are you ok now?
grifterkid
#20 Post by grifterkid »
I've burried my head in the sand a little bit on this one as I've been ruddy busy of late...!!! I'm itching to get it sorted but it's just getting the time... I will drop you a line soon Jon and we can have a look and see what's what...!
