Front shock top mounts....how?
Flyfisherman
Re: Front shock top mounts....how?
#16 Post by Flyfisherman »
shaunroche
#17 Post by shaunroche »
Thanks for the help and info chaps, very much appreciated!
Looking at those threads I do have to earlier type top mount, but one unexpected thing I have noticed is that on both top mounts one of the four studs is off set, poke you style if you will, that means it will only go in in one orientation!
Is this also a feature of the earlier car?
I also note that some of the pictures of the rear damper top bushes have metal inserts, mine don't!?
#18 Post by Jon Tilson »
Non offset mounts are IIRC toledo and 1500 fwd and go with a narrower spring.
All dolomite and Sprint ones are offset as I described.
shaunroche
#19 Post by shaunroche »
Aye, I got the offside one spot on first go but after a few goes the nearside is still not right.
Cheers for that Tony, I'll give that a go tomorrow. :)
