Page 2 of 2
Re: Front shock top mounts....how?
Posted: Fri Jun 12, 2015 11:17 am
by Flyfisherman
Posted: Fri Jun 12, 2015 1:59 pm
by shaunroche
Thanks for the help and info chaps, very much appreciated!
Looking at those threads I do have to earlier type top mount, but one unexpected thing I have noticed is that on both top mounts one of the four studs is off set, poke you style if you will, that means it will only go in in one orientation!
Is this also a feature of the earlier car?
I also note that some of the pictures of the rear damper top bushes have metal inserts, mine don't!?
Posted: Fri Jun 12, 2015 2:40 pm
by Jon Tilson
Non offset mounts are IIRC toledo and 1500 fwd and go with a narrower spring.
All dolomite and Sprint ones are offset as I described.
Posted: Sat Jun 13, 2015 5:16 pm
by shaunroche
Aye, I got the offside one spot on first go but after a few goes the nearside is still not right.
Cheers for that Tony, I'll give that a go tomorrow.
