I couldn't find enough data for the Sprintspares kit; however, I did find nearly enough on the Sierra 4-pot callipers to estimate the gain from them on a 240 mm rotor, which I understand is what the Trackerjack kit comprises. As I understand it, they give 39 percent more effort than the standard Sprint ones (4 x 40 mm pistons = 5026.5 sq mm / 2 x 48 = 3619.1). And while I can't be sure without dimensions, I estimate there could be as much as another 18 percent gain, if the pressure centre is moved 10 mm by the bigger 240 mm rotors and 4 to 6 mm for going to 4 smaller pistons instead of 2, depending on exactly where the pressure centre starts from (does anybody know the centre to centre distance from the piston to the hub on the standard Sprint brakes?). Anyway, if the pressure centre starts as far out as it reasonably can be, that would mean something like a 64 percent increase in effort overall.Carledo wrote:Both the Trackerjack and Sprintpart kits have been hamstrung by the need to fit inside a certain 13" Alloy wheel! This... means that no massive gains in effort are even on the table
That, to me, would be a "massive gain" because it's far and away more increase in effort than I can ever get in extra grip with road tires. And I'm not sure what tires you would want, that would fit on a 13 x 5.5 inch wheel, and give you anything like 64 percent more grip. That's a CofF of something like 1.5!
I don't deny that the bigger, vented rotor and bigger pads are attractive. Though they're not really necessary for me, as I don't push the car so hard I ever get brake fade. And between the longer pedal and less force on it needed to lock the wheels, I would worry about the loss of finesse in normal braking. So I think fitting the Sierra callipers would mean modifying the hydraulics on my car as well, essentially to lose much of the gain in effort and provide the extra 30 percent or so hydraulic fluid they will need to work. And life is definitely too short for that.
