Battery keeps depleting over night
Re: Battery keeps depleting over night
Mine was the boot light switch not adjusted properly, had me looking far a while!
An easy way of testing the "boot light theory" it is to disconnect the boot light or remove the bulb and seeing if the battery drains overnight.
Or, if you suspect the boot light being on when shut, put a mobile phone in the boot doing a
video recording of the bulb, close boot and check recording.
no boot light!!colinwoods wrote:Thanks all. Excellent responses...
So, I've ordered an ammeter as I think these are good to have anyways. I don't have a light in the boot, so it can't be that.
I have had the battery drain all the way the past a couple of times by leaving a light on (classic) of which I understand can kill a battery. And, the car has not been driven for nearly two months whilst the rust was getting sorted. Would this have killed the battery?
Trevor
2017 Jaguar XE R-sport
- GrahamFountain
I take it you've eleminated the battery itself being at fault, by disconnecting it overnight and seeing that it does not still drain?
