Erratic idle (1850) - SOLVED
Re: Erratic idle (1850)
#16 Post by MIG Wielder »
Hi Dave, my 1850 has an occasional problem of the jet on the front carb being sticky. You can pull the choke; it starts fine but when it warms up it runs a bit rough. If you press upwards on the jet on the front carb there will be a click; and it will go back to its correct position. I've never found out why.
Karlos
#17 Post by Karlos »
A nod's as good as a wink to a blind bat, eh?
#18 Post by Toledo Man »
FYI, my carbs are the non-waxstat type. I'm going to pull off the carbs anyway and replace the gaskets with the black instant gasket type sealant so I won't bother to find out if there is a leak. If nothing else, it will eliminate the carb mounts as the source of any air leaks.
Alun, you forgot about the other 2 Pythons (the Terrys).
Karl, I replaced the breather tubes recently so they should be fine.
#19 Post by Jon Tilson »
Proper paper SU gaskets are the thing to use....with hylomar on the manifold side and a thin smear of grease on the other.
If that doesnt seal nothing will - you have distorted faces, probably on the carb adaptors.
That instant gasktet goey stuiff is that last thing you want anywhere near carbs....
Find the hiss with a tube in your ear. Then you will find out how to fix it.
#20 Post by xvivalve »
No I didn't!
#21 Post by Toledo Man »
Jonners, you were right. There was an air leak with one of the mating faces of the carb mounts. I also take your point about the instant gasket stuff but it is only a problem if you use too much. I just did a thin bead so it will be fine. It will do until I get some solid carb mounts. I've put together a video and I've posted it to YouTube. Sealing the mounting faces of the carb mounts has cured the problem.
James467
TDC Sprint Registrar
#22 Post by James467 »
Solid carb mounts for your's are in stock Dave!
James
#23 Post by tony g »
xvivalve wrote:No I didn't!
Yes you did, you invaded Poland!
Re: Erratic idle (1850) - SOLVED
#24 Post by tony g »
I'll get me coat
Karlos
#25 Post by Karlos »
Ni! Ni!
#26 Post by xvivalve »
Excuse me, is this the right place for an argument?
#27 Post by Mad Mart »
I've told you once!
#28 Post by Jon Tilson »
That's not an argument, its just contradiction.
