Page 13 of 25
Re: KLJ895W tinkering...
Posted: Tue Jul 16, 2013 7:02 pm
by lazeruspete
Posted: Thu Jul 18, 2013 7:26 pm
by lazeruspete
more progress!
new boot floor
this bit was tatty! (drivers side rear wing trailing edge)
this bit replaces it
welded in!
finished off
and with zinc primer
here is the other side for reference
that was one days worth. the next day coming up!
Posted: Thu Jul 18, 2013 7:44 pm
by lazeruspete
i looked at the doors. as usual, there is rust evident and also bodging!
this is the worst one; a large patch in the bottom of it. not looking forward too much to taking it apart....
we also started looking at redoing the firewall. the old one shown doesn't fit very well
we used the old one as a template and essentially filled in all of the gaps, and came up with this.
quite alot of cardboard engineering happened today. decided to fill these in too.
the bottom panel is aluminium and the top cardboard(i went home today before i could transfer it to ally)
let me know your thoughts!
Posted: Mon Jul 22, 2013 10:39 pm
by lazeruspete
what is the next thing on the list, i hear you say?
ENGINE INSTALLATION.
awwwwwwwwwwww yeah.
slight change of plan......to a vauxhall redtop. reliable power which i could only dream of if i was using a triumph lump.
so, here goes.
here is the block plus adapter plate and Type 9 gearbox.
the assembly in the car. we are aiming to have the block positioned slap bang in the middle of the subframe
and with head!
and lovely red cover thing. today it was just proof of concept really, deciding which thing to do first.
so therefore we are making some engine mounts tomorrow!
happy to answer any questions you may have!
Posted: Mon Jul 22, 2013 10:44 pm
by maximus
Looking good
Posted: Mon Jul 22, 2013 10:47 pm
by lazeruspete
maximus wrote:
Looking good
thanks
Yes...
Posted: Tue Jul 23, 2013 9:32 am
by sprint95m
lazeruspete wrote:happy to answer any questions you may have!
Are you going to have to modify the gearbox remote to allow the gear lever to clear the transmission tunnel?
Which T9 are you using?
Which clutch components?
Cable or hydraulic?
Posted: Tue Jul 23, 2013 9:37 am
by lazeruspete
Ian,
I think we are going to chop the gear selector tunnel and shorten it.
It's a Sierra 5 speed.
Clutch, I don't know yet.
Probably hydraulic.
Posted: Wed Jul 24, 2013 8:36 pm
by lazeruspete
Look! Engine mounts!
firstly, the nearside.
in cardboard first
and then into a big slab of metal!
on the engine...
then a piece of roll cage tubing welded onto it. weird coincidence that the bushes that alan had fitted into roll cage tubing!
on the car again. along with a piece on the subframe engine mount
some ears!
welded together!
Posted: Wed Jul 24, 2013 8:58 pm
by lazeruspete
and now the other side!
firstly this was welded onto the subframe
we used this rather nifty contraption to cut some more roll cage tubing on an angle to go between these...
two parts. essentially the same construction as the other side but since the engine is further away from the subframe on the drivers side it needs extending!
a bit like this
we gusseted the underneath
and the best thing is, the bonnet closes!
with just under an inch of clearance
i am away tomorrow, friday and over the weekend so there will be more updates next week!
i will answer any questions
Posted: Wed Jul 24, 2013 9:58 pm
by Tony Burd
Great work as usual, what bits are you using from the original car?
Posted: Wed Jul 24, 2013 10:22 pm
by lazeruspete
Good question!
Not alot.
Front suspension.
Wheels.
Chrome bits.
Rear suspension
Glass.
Can't think of anything else!
Posted: Thu Jul 25, 2013 2:16 pm
by straylight
you sir, are some kind of mechanical genius.
this must take massive amounts of time to sort. Well done.
stu
Posted: Thu Jul 25, 2013 2:27 pm
by lazeruspete
Timewise it was a day per engine mount. That included thinking of the idea first and then actually turning it into what to you see here.
I would just like to reiterate that it is not me who is the mechanical genius. I just take the pictures and fabricate the odd bracket or two
But thanks for the compliment and I will tell Alan you said so
Yeah.......
Posted: Thu Jul 25, 2013 6:41 pm
by sprint95m
That is looking awesome,
respect to Alan
