Bruce the FWD
Pauldaf44
Re: Bruce the FWD
#316 Post by Pauldaf44 »
Ok here are some photos of a hopefully MOT worthy Bruce. Unfortunalty I still haven't been able to find the phone lead so ive been out with the digital and taken a few finished shots. Anyway here we are.
First is the inner sill. No holes there the patch is visable but will be hidden by the sill carpet anyway. For this reason it probably wouldn't have failed an MOT but it was structural so needed to be repaired. The rest of the passenger floor pan is nice and solid
As you know whilst that was being done the scuttle corners where attacked with the DA and then resprayed. They now look like this
A small amount of extra sanding is still required but it looks reasonable unless you get up close. Here is what my low cost rebuilt arch looks like. Reasonable untill I can afford repair sections
Then moving onto the rear jacking point. The view from the rear wheelarch shows the sill end closed and solid thankfully my welding is starting to look ok.
Looking from underneath there are 3 visible sections but again it should now be lovely and strong. I have tested it and it will jack up from the jacking point. Not that I normally use them anyway. ;)
Final bit was above the spring mount and is a pig to photograph so please excuse the shoddy pic as I was not removing the road wheel for the sake of a photograph.
lastly today saw me rectifying a niggling problem. I had the problem of a gear knob that regularly came off and ended up on the back seat when changing gear. So it has a new one, I know the purist are going to hate me for using a non-triumph item but I think it looks the part and its my car so my way ;D
Paul
1300dolly
Re: Bruce the FWD
#317 Post by 1300dolly »
There sure is some crap on ebay.
Do you want an original knob Paul?
Re: Bruce the FWD
#318 Post by DoloWIGHTY »
1300dolly wrote:Do you want an original knob Paul?
:lol:
Pauldaf44
Re: Bruce the FWD
#319 Post by Pauldaf44 »
My cars not had an original knob all the time ive owned it, and personally I think a wooden knob suits the car. I wonder why triumph didn't in the first place really. When I got it had a standard triumph badge on the gear knob but as the whole knob kept coming off I ditched it :D
Re: Bruce the FWD
#320 Post by JPB »
I can understand perfectly well why you'd want a new knob if your original one kept coming off. What I cannot understand is how the incredible, vanishing knob ended up in the back seat. :o
Pauldaf44
Re: Bruce the FWD
#321 Post by Pauldaf44 »
JPB wrote:I can understand perfectly well why you'd want a new knob if your original one kept coming off. What I cannot understand is how the incredible, vanishing knob ended up in the back seat. :o
Because my 1300 has such a nice in my opinion exhaust note that I drive it flat out so I get the burble when its on full throttle. A side effect of this is it makes me change gear a little enthusiastlically resulting in the knob flying off and ending up on the back seat. This did serve to stop me driving like a cock as changing gear fast with a bear shaft hurts your hand.
All fixed now I can enjoy driving enthusiastically without fear of knocking the rear seat passenger out with a flying gear knob :woohoo:
1300dolly
Re: Bruce the FWD
#322 Post by 1300dolly »
The original gear lever knob is a small black round one.
Howard81
Re: Bruce the FWD
#323 Post by Howard81 »
So driving like a cock causes your knob to fly off and knock out the passenger in the back seat? Oh dear :lol:
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
Re: Bruce the FWD
#324 Post by JPB »
See that bare shaft, I wouldn't want to touch it either. :evil:
Spunkymonkey
Re: Bruce the FWD
#325 Post by Spunkymonkey »
Howard81 wrote:So driving like a cock causes your knob to fly off and knock out the passenger in the back seat? Oh dear :lol:
It wouldn't if he had a small black one....
matienzo
Re: Bruce the FWD
#326 Post by matienzo »
Oh dear...where's this going! :woohoo:
Steve and Nic
Larger garage needed
Re: Bruce the FWD
#327 Post by Mad Mart »
matienzo wrote:Oh dear...where's this going! :woohoo:
If you don't know by now... :woohoo:
1300dolly
Re: Bruce the FWD
#328 Post by 1300dolly »
Pauldaf44 wrote:
JPB wrote:. A side effect of this is it makes me change gear a little enthusiastlically resulting in the knob flying off and ending up on the back seat. :
I still dont get how the knob comes off as if you changed gears properly then you dont actually grab or hold the gear knob, you should use the palm of you hand with finger upwards to change 2-1, 4-3 or 4-1 and with your palm and fingers down to change 1-2, 3-4 and 2-3.
At no point regardless on how fast you cahnge gear should the gearknob be gripped!
You should have been taught this when you took driving lessons.
Re: Bruce the FWD
#329 Post by Mad Mart »
What's that all about Justyn, my fingers are always down?
Pauldaf44
Re: Bruce the FWD
#330 Post by Pauldaf44 »
i dont grip the knob if I did it might not come off :D The old one was such a loose fit that it would come off all by itself and rotate whilst the engine was running. Flat of the palm would knock it off without fail
