Another vote for a vinyl roof here..
Inspired colour choice..please keep the great updates up.
yeah that was the other option.
Hi Jeroen,soe8m wrote: ↑Wed Feb 20, 2019 10:07 am Are you sure those rear axle modifications will work? The angled reaction rods have to take both axial and radial movement of the axle and a round bush isn't designed for that. The two half donuts make it be able to move and pull in all directions. The more solid round ones will cause a lot of stress on the pick up points not being able to move freely. These rods also aren't moving parallel when the axle moves up and down and when cornering when the body angle's over the axle making an even more out of line suspension arms. The round donut ones making the rods be able to turn and twist in the pick up points as your bush modification cannot only stressing body and axle brackets even more.
These rods are a not ideal contruction acting as axle location all way round in all directions but this way using round bushes something will shear I think. I would keep a close eye on the axle pick up points when going to drive your car.
