The Little White Tolly
Lord Tolly
Re: LittleWhite Tolly
#61 Post by Lord Tolly »
Ah but Phill my car was made in the 70's so I think this one is more appropite
:D :lol:
Purplebargeken
#62 Post by Purplebargeken »
:lol:
Lord Tolly
LittleWhite Tolly
#63 Post by Lord Tolly »
Tommorw is going to be a big day tomorrow.
Weather is ment to be ok so we are going for it tomorrow on the Tolly with starting it up and getting her ready for her Mot Next month.
Everything has been put back together and checked, battery is on charge and should be ready by morning.
Lumeniton electronic Ignition Purchased.
Spin on oil filter conversion now on the car after oil change of what I can describe as the most filthiest oil in the world was drained out.
Cant wait to hear her purr again :D :D :D
#64 Post by DoloWIGHTY »
How did it go Glenn? Does it live mate?
Lord Tolly
#65 Post by Lord Tolly »
not yet this weekends effords were unfortunatly rained off so fingers crossed this weekends weather is ment to be kinder for me :D :D
#66 Post by DoloWIGHTY »
Fingers crossed for you.....
oIPJDM#]D,,c
Actually I'll uncross them for now as I cannot type like that it would seem :oops: :lol: .
Lord Tolly
#67 Post by Lord Tolly »
Its Raining again AAAAAAHHHHRRRRGGGHHHH !!!!!!!!! :cry: :cry: :cry:
Lord Tolly
LWT Going For it Tomorrow
#68 Post by Lord Tolly »
Well tommorow is forcast as being dry so enough of the faffing about so I am going for a start up!!! :D
couple of questions;
what do you recomend putting in the dashpots on the twin su's???
want to set the static timing before I start up what size is the big nut on the crank pulley
and being a novice at timing how do I set it?
also tommorow if all goes well I want to take a peek at the spare engine I got only ting is previous owner was unsure on wether it was a 2.0tr7 or a 1850 is there any way of easily telling without stripping it down???
Cheers in Advance
Glenn :D
Re: LWT Going For it Tomorrow
#69 Post by JPB »
Lord Tolly wrote:what do you recomend putting in the dashpots on the twin su's?
ATF is the best stuff to use, it doesn't get thick when the weather's colder and its excellent film strength means that, although it appears thin, it lasts well.
I use Shell Donax in the (Strombergs, but same basic principle as SUs) carbs on mine for the simple reason that it's what the gearbox takes and I had plenty left for the carbs after the last gearbox oil change. Any basic, cheap ATF would do the job though. :)
Fingers crossed for your starting it up tomorr... er, later today! Sheesh, I must get to bed sooner..... :lol:
Lord Tolly
#70 Post by Lord Tolly »
Cheers John
looking forward to hopefully hearing her roar again.
Pity the weather has been so hit and miss the last month or so as I would have had her running sooner.
also got my brand new old stock washer jets turned up so will be hopefully fitting those too as apposed to the knackered ones fitted at the moment that have a mind of thier own where they point. :D
Lord Tolly
#71 Post by Lord Tolly »
Well some progress was made today.
Everything was in place battery freshly charged up new coil on as the old one was a bit suspect.
cranked the engine over plenty of fuel but nothing!!!!
some reason I dont seem to be getting a spark!!! :(
checked all conections replaced points (electonic will go in at a later time when I get round to fitting it to my spare dizzy
checked the feed coming to the coil and down the low tension all seems good.
rain stopped play in afternoon so will try again next weekend when my frozen hands have defrosted
any Idea's fella's???
would a naff condensor stop a spark beng produced??? :?
Triumph1300
#72 Post by Triumph1300 »
Try the old coil back on it...........
Why did you change it?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Lord Tolly
#73 Post by Lord Tolly »
just changed the coil and all the rest of the ignition system as a matter of precaution.
both coils are working good one's
personally I think it has a duff earth braid as discussed in my other thread
will get it sorted hopefully this saturday :D
Lord Tolly
#74 Post by Lord Tolly »
Well had another look tonight at the lack of ignition and to be honest im baffled.
So I have called on the assistance of a good mechanic and auto electrical wizzard friend of to pop over this weekend and fit my lumenition and give the beast a thorough going over.
will be nice to hear the ol beast roar again..... :D
Lord Tolly
Re: waterpump of doom...Almost Finished
#75 Post by Lord Tolly »
Very Big Day tomorrow
Lumeniton now fitted to my spare dizzy.
what fun that is...actually not too bad apart from removing a very stubourn roll pin to get the bottom gear cog off
weather forecast is ment to be sunny with the outragous outside temperature of 13oc
carbs have all been checked and cleaned through everything is operating as it should
fingers crossed...lucky rabbits feet and heather on standby :D :D :D :D
