Ice Blue Dolomite 1850 auto
Re: Ice Blue Dolomite 1850 auto
#61 Post by MIG Wielder »
Yes, this is guaranteed to be an L.T. electrics problem.
Just to expand on this a bit......
( This all assumes you have points and capacitor ignition with a ballast resistor. If not see the bit at the end. )
1. Did the red IGN light come on at the same time as the rev; counter dropped to zero and the engine cut-out ?
If so it will be a dodgy connection on the thick brown wire to the connector block on the battery + lead, a faulty Ignition switch, or a dodgy thick white wire from the Ignition switch as far as the splice connector. ( This is equivalent to turning the ignition off.
2. If the red IGN light doesn't come on when the fault occurs, then go back to the fuse box. If you have an early 1850 <1500 then the Ignition circuit doesn't actually connect to the fuse box; neither does it on LHD > 15,000 so ignore this bit. So if you have an RHD 1850 >1500 you will find 2 white wires on the fuse box. This is your first check. They may be 2 wires on separate tags or 1 connector with 2 wires on it. Check these connections.
3. Then check the white wire connection to the in-loom ballast resistor ( white / pink wire ) With an early 1850 on Strombergs you may have a ceramic block by the coil. Check these connections next.
4. Then check the white / yellow wire on the coil + terminal.
5. Now check the white black wire on the coil - terminal.This should go straight to the distributor. Follow it through to the points connection inside the distributor. ( This is where my 1850 had a broken wire at one time. ) Finally check the braided earth wire is still on the base plate. I've never been convinced on the necessity of this, but A.C. Delco must have fitted it for a reason.
6. From 5 above if you find the wire goes back through the bulkhead and then re-appears then you have a very early current sensing rev; counter. A fault in this will stop the L.T. electrics, but is quite an unusual fitment.
7. And do check the points gap is O.K. Points sticking open will give the same problem. A short circuit capacitor ( or the wiring to it ) will also give this problem.
8. If a wiring / connector check reveals nothing then it can be an ignition coil going open circuit intermittently. Running with a 12V 2.2W test bulb on the coil + will tell a lot when the fault occurs
9. Now if you are running electronic ignition then depending which make you have fitted.....
Check the +12V supply to the module. This is normally on the unfused side of the IGN ON supply.
Check the module earthing. Can be via a screw on the module or on the distributor base plate.
Then its down to a faulty bit of electronics probably.
If its a Lumenition opto; unit drop me a P.M. and I can give you a few more pointers.
Let us know how you get on.
HTH,
mec
#62 Post by mec »
Hi Guys
thanks for all the info and replys, im going to check all the things you have suggested over the weekend hopefully, just to confirm its a 73 1850 auto running all standard ignition, points condenser etc, i havnt had any dash lights come on when this happens,
also to put another slant on this fault, when driving it today around 30mph it happened again, however if I move my foot on the throttle a little more to accelerate or less to coast along it goes back to normal so it seems the position of the throttle peddle has something to do with it, possibly something on the kick down circuit ??
mike
mec
#63 Post by mec »
Hi Tony
I followed all your advice and I think I've cured it ! The fuse box and all the coil connections are fine, however when it came to the wire inside the distributor I found the problem, the wire in the base coming from the coil had risen up from where it should be seated and the two small screws that hold the rotor on were hitting it when its running and broken the wire connection, i took it out re soldered it and hey presto, here's some pics...
fuse box all cleaned up
20140803_143310 (1024x768).jpg (566.51 KiB) Viewed 2735 times
the problem wire
20140803_144033 (1024x768).jpg (444.69 KiB) Viewed 2735 times
20140803_144101 (1024x768).jpg (480.06 KiB) Viewed 2735 times
20140803_144221 (1024x768).jpg (317.67 KiB) Viewed 2735 times
thanks for all your help !
#64 Post by Jon Tilson »
Nice pics there.
Looks like someone has already been at the wiring as the OE loom would have had clear boots over the lucar connectors at the fuse box.
Trouble brewing on that heater jubillee clip too...:-)
Pippin
#65 Post by Pippin »
Jon Tilson wrote: Trouble brewing on that heater jubillee clip too...:-)
And with the perished pipe below/behind it.
Jer
mec
#66 Post by mec »
Yea il keep an eye on them guys, up until this year the car was off the road since 2010 and now its my daily driver so i recken i might get a few things croping up :?
#67 Post by MIG Wielder »
Jon Tilson wrote:Nice pics there.
Looks like someone has already been at the wiring as the OE loom would have had clear boots over the lucar connectors at the fuse box.)
Hi Jon, I took your advice from previously and swapped the standard 1850 fuse box for the MGB 4-fuse unit.
And guess what. My 1850 doesn't have the clear plastic boots on the standard push-on connectors either; and its a 1977 car.
Only on the after-market accessories I've fitted.
So I've got to fit a plastic insulator by the side of the new fuse box as the fused connectors are a bit close to the bulkhead. ( Ther are aligned up/down rather than left/ right on the Triumph box).
BTW Thanks to Julian for the hint on cleaning the brass connectors with Silver dip ! Tip of the decade that one.
Cheers Both,
mec
#68 Post by mec »
I must say the wiring on my car doesnt look like its ever been tampered with, its all very original looking wires and connectors ?? :?:
#69 Post by Jon Tilson »
Fair enough...
ERO is an early one with the old grey squshy rubber loom joiners and has clear yellowy boots over its fuse box lucars.
Later ones have the harder plastic loom joiners and harder plastic square section sleeves over the fuse box lucars IME.
Long as they are clean and pass current...
Dolly-Dimple
#70 Post by Dolly-Dimple »
What a gorgeous looking 1850, love the colour. How are you getting on with the car? Hope you and Dolly are well.
Kind Regards
Russell.
#71 Post by Toledo Man »
Russell, he sold the car.
Dolly-Dimple
#72 Post by Dolly-Dimple »
Toledo Man wrote:Russell, he sold the car.
Ahh. Hopefully it stayed within the club, it was a lovely looking example, the colour really suited it.
Kind Regards
Russell.
