Re: Honeysuckle 2-door toledo - NBP
Posted: Fri Jun 23, 2023 7:54 am
Still using my speeduino 0.4.3c Dave. Tunerstudio is the preferred program to use it though there are others -it's pretty capable from what I've seen (have only really used it for basic stuff so far) but its mostly configured by the speeduino firmware, which is just some C code that runs on an arduino/teensy board. It comes with a base map, you enter num of cylinders, trigger pattern, firing order wasted spark/individual ignition and batch fire/sequential injection and a few other bits which should get the car running. The paid version of tunerstudio has a learning function which trims fuel/advances timing based on AFRs etc. which will probably do the work for you! Only thing I would say is by design its not really a "ready to go" solution like a haltech/link would be as its supposed to be generic enough that you could adapt it to an existing ECU or use it from scratch like I'm doing. Have had to decide which connectors i'm going to use etc. myself!new to this wrote: ↑Wed Jun 21, 2023 3:14 pm What ECU are you using ? how is the setup programme (easy to use ? ) did the ECU come with a basic setup to get the car started ?
as a first start all im really doing is getting it to read the temperature sensor and trigger a thermo fan relay so can't say just yet what the tuning side of it is like really - will let you know when i've done the ignition side of it.
PS I believe max with his Jag v6 dolly is also running one - he may be better suited to give his opinion as his car is further on than mine!
https://forum.triumphdolomite.co.uk/vie ... hp?t=36047
