More Tolly Tinkering
Lord Tolly
#1 Post by Lord Tolly »
Well today the weather decided to play ball so out I went to play on the little white tolly
First thing I did was to give her a damm good servicing and flush the cooling system through with dubious quantaties of filth coming out of the hoses.
Eventually running nice and clear I filled with fresh antifreeze and a new thermostat
Then I replaced the missing nuts and bolts that somehow dissapeared on the way to Luton last week.
After this I then degreased the enitre engine bay removing 30 years of crud.
Then a strange thing happened whist adjusting the washer jets.
somehow the pump and the wipers have now stopped working :cry:
oh well another job for another day
by the way craig(beerfertoo) what does those 3 relays on the dash do?
and are there any more fuses apart from the obvious 2 on the car??
Glenn
Lord Tolly
Re: More Tolly Tinkering
#2 Post by Lord Tolly »
Now fixed problem with wash wipe switch
found out the problem was a combination of iffy fuse box , faulty washer pump and the thinest cable ive ever seen powering the switch those all replaced and it all came back to life phew!!! :D :D :D
Next job on the cards tidy up of the engine bay including repaint and respray of all the componants
2Toledos
#3 Post by 2Toledos »
Lord Tolly wrote:...and are there any more fuses apart from the obvious 2 on the car??
Nope.... car electrics in the simplest form 8) If you're lucky.... there'll be 4 fuses under the cover - The 2 'lying down' are the active/live ones, and there's also a couple of holes to hold 2 spares... which is nice :thumbsup:
Lord Tolly
#4 Post by Lord Tolly »
now fitted with brand new fuse box and cover so hopefully wont be having any more electrical gremins in that department :D
