Webers (new)
trackerjack
Webers (new)
#1 Post by trackerjack »
http://www.pistonheads.com/sales/2429139.htm
48's £550 a pair and 45's £480 a pair.
I have no connectionn with the seller but thought these were a very good price.
Are they?
mbellinger
Re: Webers (new)
#2 Post by mbellinger »
Agreed Jon - that is a very good price indeed.
Martin.
2021 Dacia Duster 1.3 TCe
1963 Austin A40 Rally Car
ToledoZombie
Re: Webers (new)
#3 Post by ToledoZombie »
I would be weary of buying this way though as i have been duped before on pistonheads.
At least with Ebay you can look at the sellers history and feedback whereas pistonheads doesnt offer this.
I once bought some bargain header pipes for a Subaru on there and i never received them. The seller dissappeared almost instantly! :(
1971 2 door Toledo aka Chuckie (porsche orange)
trackerjack
Re: Webers (new)
#4 Post by trackerjack »
I agree totally but pick them up in person.
I was lucky with my Dellorto's as they were nearly new jetted for the sprint and consecutive number tags on them.
scadds
Re: Webers (new)
#5 Post by scadds »
HI ALL
Just quick question which most likily needs a long reply but is there any way of buying a pre set correctly sized jets for a pair of weber 45's
or does any one have a list of jet sizes needed ?
or is it a case of the car has to go to a rolling road set up to be set up.
cheers scadds
Re: Webers (new)
#6 Post by Mad Mart »
No is the short answer. I have a list of what I have on my Sprint, which would be a decent starting place, but you really need to get it on the rollers.
scadds
Re: Webers (new)
#7 Post by scadds »
Mad Mart wrote:No is the short answer. I have a list of what I have on my Sprint, which would be a decent starting place, but you really need to get it on the rollers.
Thanks for that! any chance of the list so i can ask for these when i order and than hopfully once i get the car back on rd full time i will get it tuned and sorted, i have owned the 1973 sprint for 26yrs after buying off my dad who bought it from new in its pretty original having only covered 37k miles still rust free and after having the car garaged up for 12yrs have decided to get her back on the rd and have decided to have a play with the engine
cheers scadds
Re: Webers (new)
#8 Post by Mad Mart »
Pump Jet - 150
Main Jet - 145
Emulsion Tube - F16
Air Corrector - 175
Idle Jet - 60/F8
scadds
Re: Webers (new)
#9 Post by scadds »
Mad Mart wrote:Pump Jet - 150
Main Jet - 145
Emulsion Tube - F16
Air Corrector - 175
Idle Jet - 60/F8
cheers just as u think you are getting your head around it !!! then notice every WEBER 45 DCOE i look at are different modle,s ie: 152 or 152G or 9 or different progresive holes can u help me by what model did u go with but again thanks for the jet sizes.
i think it looks like i want to get 152's but if u could help me confirm cheers
trackerjack
Re: Webers (new)
#10 Post by trackerjack »
My little girl Rebecca had an AX GT and would not listen when she asked if I thought it was a good idea to fit a pair of Webers as I said NO leave it alone, but she did fit them and entered a world of grief as several so called tuning firms had a go at them :cry: at one time the car reeked of fuel and was very difficult to drive.
I am so glad she does not have a poxy little French car now :D
David6214
Re: Webers (new)
#11 Post by David6214 »
I have a poxy little french car now and am so glad I have it, never thought I'd say it, but don't knock the french they have made some good stuff!....it goes very well :)
trackerjack
Re: Webers (new)
#12 Post by trackerjack »
David6214 wrote:I have a poxy little french car now and am so glad I have it, never thought I'd say it, but don't knock the french they have made some good stuff!....it goes very well :)
You clearly have not had to work on one yet :wary: they are the work of the Devil, but drive okay.
Who but the French use 7 mm bolts ?
who but the French would bolt a seat in with long bolts that stick out underneath the car and go rusty so that they break when you try to remove them?
Who but the French would have the fuel pump earth wired in to the back lights?
Who but the French have brake bleed nipples 6mm diameter that ALWAYS break and ruin the caliper?
Working on a Triumph after a Peugeot is bliss.
However once you drive a Pug 205 GTI in anger, all is forgiven 8)
Re: Webers (new)
#13 Post by JPB »
Who but the French use 7mm bolts?
A little outfit known as Ford. Apparently they used them in various locations around something called an "Escort". No, I'd never heard of them either... :mrgreen:
speedracer
Re: Webers (new)
#14 Post by speedracer »
Main Jet - 145
Emulsion Tube - F16
Air Corrector - 175
Idle Jet - 60/F8
Hey Mart,
I might shamelessly plagiarise this list, have just tried 50F9 idle jets and found them too rich...
Cheers,
X-pat
Re: Webers (new)
#15 Post by X-pat »
Could someone running twin Dellorto 45s mind telling me what the jetting is on their car, for comparison, please? I'm running the following at the moment:
60 idle jets
7850.1 idle jet holders
7772.5 emulsion tubes
160 main jets
180 air correctors
42 pump jets
36mm chokes
TIming now set at 16 degrees BTDC.
Thanks in advance.
Andrew
