I've copied the below text from a stromberg manual but am unsure of one point, after initial setting has been acheived, do I still need to hold the air valve down on the bridge in the throttle bore to carry out any final adjustments on the mixture setting using the underside jet or can I just turn the jet?
Stromberg manual text
The idling speed itself is governed by the setting of the throttle-stop screw. While the idling mixture is controlled the jet adjusting screw in the base of the carburetor float chamber and when the idling speed is being set or adjusted these two controls must be used in conjunction with each other. Engine speed is set in the idle position by the throttle stop screw while the jet adjuster determines the richness or otherwise of the fuel/air mixture.
To set the idle speed the air cleaner and damper must be removed and the air valve must be held down on the bridge in the throttle bore. Using a coin the jet adjuster should be screwed up until the jet is felt to contact the underside of the air valve, at which point it should then be turned down again three full turns. By doing this you can establish a working position for the jet.
With the engine at normal running temperature the idling speed should be set by using the throttle stop screw to a speed of 600-650 rpm and by careful and gradual adjustment of the jet adjuster, vary the mixture until the engine runs with a smooth regular beat.
To check the final setting, lift the air valve a very small amount – no more than 1/32 inch and if the engine speed rises appreciably, the mixture is too rich, if it stops the mixture is too weak. If the setting is right, the engine speed will either remain unaltered or may drop very slightly.
Turning the jet adjusting screw clockwise will weaken the mixture, turning it anti-clockwise will make it richer.
