the next couple of days I had other things on, then I came back to it with the help of Oli (between us, we though it was possible to lift the engine & gearbox off the subframe
So we settled down to stripping all the suspension, suprisingly not a single not or bolt was siezed, which made our life a lot easier. Attempted lifting the engine off the box, but failed at that too
So that afternoon, I finished taking all the suspension parts off, pressing out the bushes etc ready to clean them up and paint them.
The next few days involved spending hours cleaning all the parts with a wire brush wheel stuck in my pillar drill on the highest speed. Worked much better than the leccy drill
Only problem was that the pillar drill woudl get a bit hot if used for more than about 40 min continuously
So I'd clean a few parts, then paint them, do a couple of other bits then come back to it.
Once the parents had come home from their short holiday, I burdened Dad with the task of going to pick up Oli's engine crane. 1 1/2 hours later (too much time gassing
) We were back with the crane , but it was too dark to do anything with it
Next day, this happened
The engine at this time didn't get anything done to it, except a wipe over with a few paraffin soaked rags to clean it up, and removal of the sump gasket. Big mistake (you'll see why later
A nice piccy of the inside of the engine
Over the next few days, the pile of new looking parts increased to look like this
I bought superflex polybushes for all the suspension, except shocks (cos I couldn't be bothered, as I'm hoping to get new shocks and springs anyway), and the lower wishbone one, as I couldn't find them on the superflex site
The subframe took the best part of two days to clean up (And I've now joined the knotted wire brush wheel crowd!!!), and ended up looking like this
I had already ordered a new engine mounts, and some of you may be able to see the solid steering rack mounts I bought from Jigsaw
So the assembly started with this using new nuts and bolts for nearly everything
To this
The result a couple of days later
CVs were replaced (well, one of them, as the second one I bought from Mick Dolphin turned out to be used, so another is on the way), as well as boots. I couldn't resist having red brake callipers, despite the fact they can't be seen behind the steel wheels...
Also bought a new rocker cover, as mine was warped, and leaking where it wasn't sitting flat. So I decided to get a shiney Alloy one
And getting ready to lift the car over the engine
After that, I didn't take any more pics unfortunately
It all went back together, and was back in running condition by the next day. The day after, I decided to take my car to the Lambourne vintage machinery show, which highlighted a few problems - see the next post
