Noisy diff and it's all my fault
I'm doing some mad mad hours for work at the moment and as a result Tuesday before last I was travelling home on the M23 at 21:00 instead of the more usual M25 at 18:00. This meant I had the road practically to myself and a strong desire to see my bed. The usual 70 elephants cruising speed became a less car friendly 90 elephants. Wednesday morning the slight increase in diff noise was immediately noticable. By Thursday evening it was pretty darn noisy (80 miles a day). I topped up the oil Saturday, it didn't need much which improved it a little.
It's not got any worse or better since then, is there anything I can do? I've never done any work on a diff so I've no real idea of the internals. Is the 1500 diff a collapible spacer type and if so could I have collapsed mine? It is noisy under load and quiet on overrun so I'm pretty sure its the cw&p not bearings.I'm hoping the rapid onset of noise means something has gone which can be replaced.
I'm planning to do the rear wheel bearings over the bank holiday weekend weather permitting, is there anything worth a try on the diff or do I just plan to send it off for a new cw&p somewhen?
Tinweevil
Tinweevil
No, don't have a photo but can easily be arranged. When do you need the use of one. I was thinking I could take the dims. & draw one up for you so that you could make your own?
Edit:
Edit:
You're on and I really hope I lose.
Not yet and I don't think your chances are good. I got the bearings ages back but have not had time to fit them yet. I hadn't any real reason to do 'em except that they had not been done in recorded history. Previous previous owner had the car from 62599 miles in May '86 and kept scrupulous records. Previous owner didn't have it long and did little. After I did the fronts recently I thought I ought do the rears as well. Since the Le Mans trip of 600 very heavily laden miles the bearings are now pretty noisy, easy to diagnose so I'm positive the original noise is the diff. Bearings are not anywhere near head turners yet but they are catching up with the diff fast.
Tinweevil
Tinweevil
