1500 TC Door Seal
sanderjurkiewicz
1500 TC Door Seal
#1 Post by sanderjurkiewicz »
Hi All,
What do you call the seals that fit between the door glass and the door on the outside of the car?
Is it a door glass weather strip seal?
Would RimmerBros be the best place to get them from?
Just opened the windows of my new 1500TC and feel they need replacing as they look too worn with gaps in them.
Might temp repair them with tape until I know which new ones to get for all for doors.
Any advice would be much appreciated.
Sorted the tuning issue by the way...
Many thanks
Sander
sanderjurkiewicz
Re: 1500 TC Door Seal
#2 Post by sanderjurkiewicz »
Hi All,
I'm looking at the Door Glass Outer Weatherstrip Seal - Set of 4 from RimmerBros for 42.86.
Are these the ones?
Anywhere cheaper maybe?
Many thanks
Sander
james_r_lucas
#3 Post by james_r_lucas »
All I can say here is that the sets I ordered from Rimmers don't fit very well. (It was a year or more ago though)
I ended up using a different type of clip than those supplied, and cutting away some of the rubber. It's helped, but the drivers door one keeps coming loose on mine, I think there are now 3 clips in the bottom of the door :oops:
I'm not too sure where else to get them from though, maybe someone else can enlighten use (I'm after a new set too!)
Edin Dundee
#4 Post by Edin Dundee »
Get them (and the clips) from Chris Witor.
#5 Post by JPB »
Edin Dundee wrote:Get them (and the clips) from Chris Witor.
/\/\/\ What Bill said! 8)
sanderjurkiewicz
#6 Post by sanderjurkiewicz »
Thanks Both,
Have ordered them, 23.94 including postage.
Bargain.
Many thanks
Sander
sanderjurkiewicz
#7 Post by sanderjurkiewicz »
Thanks Ken,
Just got some new ones at Canleys Warwickshire.
Like you said, didn't think it was worth risking for 37 pounds each.
Fitting them tonight.
Sander
