Sprint water pump removal
Posted: Sat Mar 02, 2013 8:18 pm
by Flyfisherman
Guy's
Help required - please.
I need to replace the water seal on my water pump, I've removed the alloy cover from the block, I have placed a ring spanner on the spindle nut and I have horizontal movement or side to side movement - i'm thinking if I rotate the pump assemble to the right should it wind its self up of the jack shaft - if not how do you remove the pump assembly.
My manual does not going into greater detail as I would like.
Quote from manual:
Using a spanner on the impeller centre bolt, turn clockwise until either:
a. The water pump is released from the jackshaft gear and it can be withdrawn
b. the centre bolt is removed
if b applies attach special inpact tool and adaptor to remove pump
Regards
paul
Re: Sprint water pump removal
Posted: Sat Mar 02, 2013 8:24 pm
by Mad Mart
Usually 'b' will happen. You then either insert a slide hammer or use a large washer & a couple of screwdrivers (or whatever) to prise it upwards.
Posted: Sat Mar 02, 2013 8:40 pm
by Flyfisherman
Mad Mart wrote:Usually 'b' will happen. You then either insert a slide hammer or use a large washer & a couple of screwdrivers (or whatever) to prise it upwards.
Thx Martin - will try this tomorrow.
Regards
paul
Posted: Sat Mar 02, 2013 9:45 pm
by Jon Tilson
Water pump how to guide is here...
https://www.dollywiki.co.uk/wiki/Water_Pump_Overhaul
Posted: Sat Mar 02, 2013 10:05 pm
by SprintMWU773V
Slide hammer is the way to go.
Posted: Sun Mar 03, 2013 3:33 pm
by beans
Usually getting the pump out isn't the biggest problem, the brass cage can be a bit of a pain to remove.
Easily solved with this simple tool I made of bits lying around in the garage ...
Posted: Sun Mar 03, 2013 5:38 pm
by Mad Mart
Similar to mine...
Posted: Sun Mar 03, 2013 5:43 pm
by dursley92
Beans your kit looks beautiful, as always.
I made one out of garage junk very much like Mad Mart's and it worked perfectly.
Posted: Mon Mar 04, 2013 7:48 pm
by Jon Tilson
Mine always bump out with a slide hammer if they stay put. Never quite worked out why they stick being brass and only 2 O rings...
Some folks must just be unlucky.
Posted: Mon Mar 04, 2013 7:51 pm
by Mad Mart
I've always wondered that, but I've had plenty that leave the cage in and it just won't budge. I always put a smear of grease on them when replacing.
Posted: Wed Mar 06, 2013 12:04 am
by whitenviro
Typically "b' will happen; so I then put a larger washer under the bolt and threaded it back in. That gives you more to pry up on if you don't have a slide hammer. But its easier with a hammer, even if you have to make one up. I made a simple slide hammer out of old plumbing parts and bolts.
My pump came out easily, so all I had to do was get the brass cage out. I used a 1/2" carriage bolt at the bottom of the slide hammer. You can insert that through the cage, hook the bottom and tap it right out.
Good luck!
