steering fault
red rooster
steering fault
#1 Post by red rooster »
hi all just got my dolly in for pre mot check and brake pad change and mechanic says theres play in steering rack now panicking as dont know what the hell is wrong can it be adjusted out or am i doomed to buy a new rack if so how much and where seriously concerned any help or technical advise much appreciated :oops:
Dolly-Nut
Re: steering fault
#2 Post by Dolly-Nut »
It's usually the rack mounts, they do wear out...
You could try tightening them up or replacing with a poly alternative.
red rooster
Re: steering fault
#3 Post by red rooster »
thank you any suggesttions where and how much mounts are?
Dolly-Nut
Re: steering fault
#4 Post by Dolly-Nut »
RimmerBros and about £15 for a pair I expect.
Bare in mind that Dollys have 'loose' racks in general and MOT testers usually point it out because they're used to boring moderns.
red rooster
Re: steering fault
#6 Post by red rooster »
yup have ordwred a set many thanks for advise
