Now my engine rebuild is continuing I think a rev limiter will be essential so I can rev to 7500 without occassionally ending up over 8 when my enthusiasm and inattention get the better of me!
I did try before with an electronic unit (Shift-Rite) but gave up as it was cutting out inconsistently, sometimes as low as 3500-4000. The auto electrician who looked at it said the problem was the electrics / wiring producing spikes all over the place. However, he couldn't offer a solution.
Other than a Magnetronic unit in the distributor, the rest is basically standard. Anything more modern / sophisticated isn't allowed in the series I race in - it all has to be 'period'.
What are others using successfully in similar circumstances?
Geoff
Rev limiter
- gmsclassics
Re: Rev limiter
First of all what have you done to your engine to get 8,000rpm?!
For me it has to be Omex. I have a launch control/limiter system fitted to my other single coil car and it works perfectly. Easy to install with 4 wires and really small. They go on eBay for £60-95 depending on which type you want (with or without launch control).
- lazeruspete
Re: Rev limiter
this also interests meDolly-Nut wrote:First of all what have you done to your engine to get 8,000rpm?!
viewtopic.php?f=19&t=23031
Proud TDC Member!
Proud TDC Member!
Re: Rev limiter
Downhill????????
Lightening rods and flywheel and then balancing. With a decent camshaft and carbs you can rev this and have some power left.
- gmsclassics
Re: Rev limiter
Yes, just as Jeroen says.
Specialist who ported the 'new' head reckoned it should flow 10-15% better thn the last one. Given in first and second (CR g'box) the previous engine would happily scare me by going past 7500 if I wasn't paying attention, I want to try and preserve my investment this time!
Geoff
Geoff
Re: Rev limiter
Not sure this could be clasified as period but I use one of these
http://www.msdignition.com/Products/Ign ... ntrol.aspx
