A weird and worrisome coolant leak
USASPRINTMAN
#1 Post by USASPRINTMAN »
OK. So I fired up my new Sprint engine tonight.
She's feels like she's going to have a lot of power.
But there's a snag.
Coolant is leaking from one of the bolt holes in the water pump cover!
What? I have never heard of this. The cover is a new NOS 12 vane. The pump is new. The leak is not coming from anywhere else.
I notice that when the coolant in the headre tank goes down 1/2 way, the leak stops.
I turned off the engine before it got hot.
Any ideas why water would leak out of a bolt hole? I have used the proper sized bolts, and there's a washer under the head of the bolt. I have tightened down the pump cover as per instructions.
Could I have used too many gaskets?
Help!
Richard Truett
#2 Post by Mad Mart »
Richard, did you put the cover on with no gaskets & measure the gap with feeler gauges first ? Then put on gaskets of that thickness plus 0.010" ?
#3 Post by xvivalve »
This has happened to me too.
When you put on multiple gaskets the torque of tightening a bolt can rip the top gasket as there is a slip plane there and by ripping the gasket you create a water path for the leak. Annoying. I now make sure there is much hermetite in this area and also 'glue' the multiple gaskets together with the stuff before fitting them to the block.
USASPRINTMAN
#4 Post by USASPRINTMAN »
thanks for the info.
It looks like I will be pulling the intake later today. Luckily, I have a zillion gaskets. I followed the instructions in the Haynes, but I can go with more gaskets because the thickness can be between 10 and 25. Maybe I messed up here. Got it right on my Stag, though.
Other than that, I think the engine is gonna be pretty nice. It runs quiet, no valve noise, so at least I finally was able to get that right.
RT
