This is the car that Sprinting put up for sale last year which i bought. Its current condition is pretty good now, nearly ready for rego.
The work its had on it so far:
-All new suspension bushings
-New front lower balljoints
-New grease in front bearings with correct float gap set
-Rear handbrake pressure level in rear hubs set
-New rear diff oil, front diff seal
-Gearbox oil
-New undercar handbrake boot rubber, link
-New unijoints in driveshaft, repainted driveshaft
-New fuel filter, cleaned gas tank
-New oil pump up front
-New engine mounts, gearbox mount
-New accuspark ignition kit
-New spark leads, spark tube seals
-Mild ported intake manifold, high flowed and rebuilt carbs
-New carb jetting needles, float bowl, float needle and seats, piston dampers, k&n filters
-Brake/Clutch pedal rubber
-Overrider rubber for fr bumper
-Gasket seals for blinkers/tail lights
-New Reverse light/brake light lenses
-Couple other seals and stainless screws
A lot of things like the radiator, alternator was in good nic, and the hoses. Not much rust on the firewall or anything like that. It had a repaint in the 80-90's im assuming and left to sit in the garage so it didnt collect much rust since then. The only others spots are a bit on the rear left door and boot lid, and front right subframe.
Really good spot of the original emerald green.
-Michael
