SPEYSIDE 2006 ----- WHIT FUN !!!!
Ken Wood
#1 Post by Ken Wood »
DavePoth
#2 Post by DavePoth »
Nice. 8)
2F45T4U
#3 Post by 2F45T4U »
did you get my PM Ken, or is it Jack, or is it Victor? :D
And WOW that is awesome! :D :D :D
Ken Wood
Above Piccy
#4 Post by Ken Wood »
Sorry Chaps that was supposed to be under 'members cars' for Adam to see - finger trouble this end
Lewis
#5 Post by Lewis »
At last, someone who can do it properly :P
How does the shell hold up to the rallying, as a matter of interest? Has it had any prep like seam welding?
Ken Wood
#6 Post by Ken Wood »
Lewis, the shell has been seam welded and fitted with a SD bolt in cage BUT the cage has not been 'tied' to the pillars - it really should be as the shell flexes especially around the front windscreen lower ends.
Ian Wilkes
#7 Post by Ian Wilkes »
Great pic! Is that an original Janspeed exhaust Ken?
Ian
DavePoth
#8 Post by DavePoth »
I have one of those in my shed...
Ken Wood
#9 Post by Ken Wood »
Ian . Yes , an original Janspeed system - still has the decal on the silencer and it must be fireproof 'cos it hasn't burned off yet !!
ALGIK
#10 Post by ALGIK »
Nice
looks great fun :D
2F45T4U
#11 Post by 2F45T4U »
So by seam welding a shell do you basically go over every spot welded surface and seam it? Do things have to be seperated first then seam welded?
2F45T4U
#12 Post by 2F45T4U »
From a different angle? :P
tinweevil
One helluva lot of wire ' gas
#13 Post by tinweevil »
No need to undo the spots welds except where outer panels need to be removed to access hidden joints.
