Sprint dizzy caps
2F45T4U
Sprint dizzy caps
#1 Post by 2F45T4U »
Are the two types of sprint cap interchangeable?
MalcGE
#2 Post by MalcGE »
Depends what you mean by the two types. There is only one Sprint dissy Cap with three sources of manufacture
1. Original Lucas - Lucas stamped on it (Original)
2. Same design as above, no Lucas markings - packaged in a variety of aftermarket brands. (Pattern)
3. Remanufactured item (Remanufactured)
The above are interchangeable, if you can get the screws that secure the leads undone - they corrode in and can be a real B'tard to shift, sometimes you just can't budge them.
Then you have the 'alternative cap' which needs to be fitted with the matching leads (push in) and rotor arm - although some say the standard rotor arm will fit
