you used to see minis with trailers made out of the back end of another mini and as a combo it looked very cool - mind you there were a lot of minis around then.....
If it was better made it would look ok behind a dolomite, but like you say a bit of a waste, especially treating the doors ike that....that said, how many other uses are there for the rear end of a scrap dolomite
Hmm - got to admit it - I think that's quite cool! I can just see that, sprayed Carmine red with Sprint alloys being towed behind my car - could stash my surf gear inside it too - and Bath's not so far from Swansea ...
so long as it does utilise a vehicle that would end up a scrapper, not a resto project or worse still a good one that someone got for cheap just to cut in half.....
I would never to this to a good salvagable vehicle but if i ever come across a car that is a total scrapper then its a good chance todo something different!!
That car a Enfeild had a lot of people looking at it as it is different!!
I think (I shudder to say it though) a 2 door Toledo would make an even better trailer especially with the two verticle rear lights either side of the "load area", you could then have things sticking out the back.
