Project AJP8 Update
Project AJP8 Update
Brake servo and master cylinder's (brake and clutch)have been removed along with the heater fan motor assy that use to sit against the bulk head.
New Pedal box and master cylinder's ordered should be with me Friday next week's job.
AJP8 is now sitting in the engine bay of the Sprint on a newly fabricated gearbox mount.
Hopefully sort the Engine mount's out tomorrow and then make room for the Cerbera Exhaust Manifold's.
All in all not a bad couple of day's work.
Picture's to follow at the weekend.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Not fitted the clutch as yet.
Will bite the bullet and buy a new Clutch(£550+
) once it go's back in for good.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
I only asked because I thought you needed a functioning windscreen demister to get an MoT. That depends on how thorough your MoT tester is though.
I had a Fiesta a while back with a non functioning and it was OK once you got moving, but was a nightmare if you jumped in all wet on a rainy day and steamed it up.
You should have seen everyone at Donington on Sunday driving back into the paddock with their heads stuck out the side window.
David
David
If its an issue just get a 12v plug in heater/blower from your local motor factors. You could probably duct some fresh air from one of the eyeball vents if you want to use it as a proper demister.
Something like this
http://cgi.ebay.co.uk/12v-Fan-heater_W0 ... dZViewItem
Thats my Plan anyway.
G
Something like this
G
