Changing rear wheel bearings
Posted: Wed Aug 06, 2014 8:21 pm
by nico
Hello!
Is there a guide anywhere on how to change rear wheel bearings?
I have dropped my Dolomite to my local garage after it broke at Castle Combe. I think it is more likely a wheel bearing failure than the diff. They have not done anything to it and seem confused on how to do the job. They are waiting for me to send them bearings and seals before attacking it more violently..... Any help?
Cheers,
Nico
Re: Changing rear wheel bearings
Posted: Wed Aug 06, 2014 8:37 pm
You need a dedicated and very strong hub puller to get the hubs off the half shafts. Even then the hub can get distorted if its REALLY tight. Various members have such a device or I believe you can still buy the original Churchill type puller (or reasonable facsimile) I'm fairly sure the TSSC shop do one as it also works on the small chassis cars (Herald, Spitfire, Vitesse etc) About £50-60 IIRC but with the power you are putting down with that beast you could be doing this a lot!
Posted: Wed Aug 06, 2014 10:52 pm
by Dolly-Nut
I also need to do this since the tight diff in my Toledo has eaten both wheel bearings. For the moment I've swapped the drive shafts with another pair but I'd also like a brief 'how to' guide. Is it as 'simple' as splitting the hub and shaft and there you go?
Posted: Thu Aug 07, 2014 7:56 am
by Mad Mart
It is pretty straight forward once you get the hub off the half shaft, as Steve said. If you don't have a puller just take the shaft to someone who has a hydraulic press.
Posted: Thu Aug 07, 2014 1:13 pm
by Dolly-Nut
I have access to a 15 tonne press but I'm unsure how to go about doing the pressing exactly..
Posted: Thu Aug 07, 2014 2:44 pm
by geeksteve
Dolly-Nut wrote:I have access to a 15 tonne press but I'm unsure how to go about doing the pressing exactly..
Put bars across press so it's just supporting the hub, with the shaft hanging.. Press on the end of the shaft. Can get the bearing off in a similar way if it's stuck. Mine made a fkcin' hell of a noise..
Posted: Thu Aug 07, 2014 7:18 pm
by Dolly-Nut
Righto. Is the nut hard to remove?
Posted: Thu Aug 07, 2014 8:15 pm
by geeksteve
Mine was alright. Electric impact got it off.
Posted: Fri Aug 08, 2014 11:13 am
by Triumph1300
The last Sprint halfshafts that I pushed out took 12 1/2 tons pressure
Posted: Thu Sep 25, 2014 2:50 am
by TrustNo1
If your garage don't know how to change a wheel bearing take the car somewhere that does.
Posted: Sun Nov 30, 2014 11:48 am
by Dolly-Nut
15 tonnes of pressure did nothing for mine!
Posted: Mon Dec 01, 2014 10:21 pm
by soe8m
Using a press does deform the bearings and they dont come off. Most of the time a big hammer does the job.
I made a how to last year using a steel wheel as a hub puller.
- scannen0002.jpg (262.16 KiB) Viewed 6227 times
Posted: Tue Dec 02, 2014 8:19 am
by straylight
Jeroen, you artist !
Posted: Tue Dec 02, 2014 11:37 am
by Dolly-Nut
Posted: Tue Dec 02, 2014 6:21 pm
by Toledo Man
Steve, that's the easy bit.
Jeroen, does this work on Dolomite rear hubs? I know that this method was used on the Herald halfshafts but the Dolly is a different beast.
Canley Classics sell the hub puller and it has been proven to work so it might be worth paying out for it. Nico, can your local TSSC members help with the loan of such a tool?
