1500 Hand Brake Actuating Lever
mjump
#1 Post by mjump »
I need a set of the above for my 1500 Dolly. I live quite close to Quillers in South East London but have had such bad experiences with them in the past I try to only use them as a very VERY last resort. Can anyone on here help me out?
Thanks.
Re: 1500 Hand Brake Actuating Lever
#2 Post by DoloWIGHTY »
The levers that operate the handbrake adjustment ratchets?
I got mine from Mick Dolphin, I am pretty sure he supplied me with the last he had of one side. However he may have restocked by now?
I believe they were also fitted to the GT6 so that might be an avenue to research.
Once I was told by someone who worked on the cars when they were current that a "fix" was to build up the worn ends with weld and then filed back to profile which may help if you are unable to locate any.
mjump
#3 Post by mjump »
This is a diagram from rimmer bros. It illustrated the hand brake set up from a TR6. number 88 is the part I am after though the one specific to the 1500 obviously. Rimmers have some reconditioned ones for a 1300 however they differ on the 1500.
http://www.rimmerbros.co.uk/Item--i-GRID600159
This is the 1300 part (6th from the bottom)
http://www.rimmerbros.co.uk/Item--i-GRID008506
Re: 1500 Hand Brake (ratchet adjuster ) Actuating Lever
#4 Post by MIG Wielder »
I see these parts are common for most of the Dolomite range.
521007 left-hand and 521008 right-hand.
I did have a quick search of the usual suppliers and their web-sites report back as not known.
Rimmers do cross-refer to another part number though. I think I would try ringing around to see who has what 2nd hand TBH.
Good Luck with your search,
TrustNo1
#5 Post by TrustNo1 »
There was a post a few months ago linking to someone who had remade GT6 items, I think it was someone in TSSC.
cliftyhanger
#6 Post by cliftyhanger »
I had the same issue. Geoff at Wins came up with a pair for £15 IIRC
#7 Post by Jon Tilson »
Geoff at Winns is the business.
You could also try Paddocks and Ficthetts. Both always do me well.
mjump
#8 Post by mjump »
Great, thanks for all your help. Winns will be my first calling point. I will let you know how I get on.
mjump
#9 Post by mjump »
Well I rang round all advised places but nobody can help. Pretty illusive part. Even Quillers couldn't help.
Looks like i'm buggered.
Thanks again for your suggestions though. If I do come across one, I will post it up on here.
PaulB
#10 Post by PaulB »
How about:-
UKC3918A HANDBRAKE GRIP ASSEMBLY SHOP SOILED TO SUIT MOST MODELS FROM THE BL YEARS £4.25
Its in the clearance bargain section of the James Paddock website.
#11 Post by sprint95m »
viewtopic.php?f=12&t=28108&p=265693#p265693
May be worth a PM to Bill.....?
